Lambo/Alarm system woes - Audio & Electronics Forum
Sunday, May 01, 2005 1:52 PM
Been trying to do the wiring for my lambos as well as install a remote start/alarm system. I'll list my problems and if someone has a suggestion on a particular problem, I'll appreciate it.
1. Interior lights do not come on with the doors, but do come on when the trunk or glovebox is open, but their respective lights do not come on.
2. When you try to use the power mirrors, they don't work but it turns on the interior lights.
3. Radio has no power, removed radio, and checked the constant and switched power leads and there was no power.
4. Flashers don't work, but the passenger indicator stays on when the parking lights are turned on.
Thats all of the problems I can think of right now, the car does start.
Both sets of wire extensions for the lambos were done one wire at a time, the drivers side I used crimp connectors, but soldered the connections on the passenger side. I am going to redo the connections on the drivers side shortly. Also, the car had a Hornet alarm system on it already, I took it off and replacing it with a Crimestopper system. All I have hooked up so far is the alarm side of the new system and just used the same tap locations when I could to hook it up. I haven't cut any wires, so this is all getting irritating.
Again, any reasonable suggestions are appreciated.
Re: Lambo/Alarm system woes
Sunday, May 01, 2005 6:05 PM
After some discussion with a mod over at the12volt.com, we think there might be a problem with my BCM, going to call the dealership tomorrow about a new one. When it comes to junkyard replacements, does anyone have any ideas what I need to be looking for. Thanks.
