Ok.
So here's the deal, I have a nitrous kit waiting to be installed on to my car. I don't really post much in this forum, i just do a lot of reading. I plan on putting my kit on in the very near future but i still have a few questions first.
Bottle heater. I bought this bottle heater with out an automatic switch to turn it off the heater when the bottle is at a good temp. Now i know that this can be very dangerous if i don't keep a eye on it (this reminds me of the fast and the furious "NOS!!!") anyways im not worried for when im in the car coz i can keep an eye on it but when i turn it off im worried i'll forget. SO if i wire the heater to my ignition fuse, then maybe put a relay and a switch there, should that work?
Also, my bottle will be mounted in my trunk, so it will be hard to keep an eye on the bottle pressure. I want to put a nitrous gauge on my dash to watch it but wouldn't ineed soemthing else so i can mount it on my dash (kinda like mounting a fuel pressure gauge on dash) i hope someone knows what i mean
2004 Nissan Maxima SE w/ Elite Pkg
2005 Infiniti G35 Coupe w/ Sport Pkg
* To install a nitrous pressure gauge inside the car, you need to run a braided nitrous line from the solenoids in your engine bay into the INSIDE of the car where the gauge will be located (gauge pillar, most likely)
*Just buy a toggle switch for your bottle warmer--stop thinking about safety so much. The worst thing that COULD happen is that the pressure in the bottle could get so high (bottle gets so hot) that it blows the release valve and empties $50.00 worth of giggle juice into your trunk or through your blow-down tube.
* ^^^ Also in regards to that topic, I've accidentally left my bottle heater on (for an extended period of time) AFTER the bottle hit 950 psi. Generally, it has NEVER climbed higher than that. Most good bottle warmers know when to turn off (via a sensor that touches to the bottle under the velcro straps or warmer itself.
it only goes to 950 psi mine goes upwards of 1100 psi and ive never blown a release valve
"dude, thats a girls car"
NOT ANY MORE!!! PSHHHTTT!!!!
if it automatically turns off at a certain temp then why are you worried about it?
Thats a mech. one, the electrical gauges are diff and lots easier
ask yourself one question, do you really want a supply of nitrous looking you in the face like that? most nitrous pressure gauges i seen are mounted to the bottle
or you could get a digital gauge that has a sending unit.... although it'd be cheaper just to buy a new warmer with a pressure/temp switch
Sure...having a gauge mounted to the bottle is really gonna help you out a lot. You can pull over every 5 minutes to see if you're up to 950psi. Real convenient.
Some people do choose to do the electronic setup--it just wasn't for me, though.
