I understand this is a Good Nitrous Fuel Pump but is it Good for an Everyday pump? What are it's downsides? Do you burn more gas? I know it helps the pressure but thats about it. Anybody have any input on the installation? Where's a good spot?? Any Pics>>? I did a Search but I didn't get to much.... I understand it's an easy install. Thanks for your help!
You wont use any additional fuel than you would with a stock fuel pump alone. If you have additional fuel needs (exp. lager fuel injectors, or additional fuel ports) it will supply the additional value needed. It is fine to run on a every day basis. You can mount it anywhere on the supply side of the fuel line. Most people mount it in the engine bay.
-Aaron
www.TurboTechRacing.com
