Paint.net is a free photo editing software, form what I've read it works very well for minor stuff, works great for touching up pics and things like that but nothign special for big involved chops.
http://www.getpaint.net/index2.html
What I'm trying to figure out if how to add a logo to a pic.
You can take a background image, and layers. I would think the pic is the background image and the logo is the top layer. I can make a new layer but I can't figure out what to do with the layer, how to put osmethign on the layer.
Basically I'm looking for a how to on how to make any pic look like my sig. I have no idea how to do that. I don't need the shadowing or anything, just the text.
thats the text/logo if it helps. Thanks
Correct. You should be able to copy and paste as a new layer... How, I'm not sure (don't use paint.net)
Here is the logo, non-antialiased (the shading bits). If someone can chime in on how to add a new layer, all you have to do is select all the white and delete. Resize it and instant watermark. If paint.net can control transparancy as well, that would be even better.
Actually, its small enough... I can d/l it and figure the important stuff out
Edited 1 time(s). Last edited Tuesday, January 02, 2007 10:16 PM
Ok.... here's what I have. Since its your thread, seems fitting to use one of your pics
Starting with this pic:
Paste your logo as a new layer
It will give this error, click on no if it does...
It should now look like this:
Hold the shift key and click and drag one of the corners to resize it.
Use the Magic Wand
To select all the solid color (I used the slightly modified version above)
Hit the delete key, it should then look like this:
Go to Layer Properties:
Adjust the Opacity
Success!
I use the older 2.8 (or whateverthehell it is) of paint.net. It kicks ass! iT's how I did my sig. Nothing special, but it works!
1971 camaro 427 --- here!
Stock... and loving every minute of it.
thanks a ton, I really apreciate it
Darkstars wrote:thanks a ton, I really apreciate it
Anytime
Bluecavi (hater of the wings) wrote:I use the older 2.8 (or whateverthehell it is) of paint.net. It kicks ass! iT's how I did my sig. Nothing special, but it works!
I just downloaded the beta version since it was the first one there
I normally use either PaintShopPro or Photoshop...
(that reminds me.... I need to un-drunken-edit my sig... photoshop + alcohol + new year's eve = bad)
whgat menu wher eyou finding the paste into new layer?
nevermind, figured out where that is but haven't figured out how you copy the image in order to paste it as a new layer
Open the logo file, Select all (under Edit), then copy.... go back to your picture file and paste as new layer
Ok I got it figured out. thanks again, I've never gotten so much (detailed) help so quick on this site before.
Its winter time... I have no life
im still waiting for our winter... all the 3-4 times we've got snow it melted instantly
