What PCM will work with my 2001 z24 LD9 with Automatic transmission? I had my car towed one day and they damaged my vehicle when it came back to my place the PCM was dragging on the ground. After that my transmission wouldn't shift into 2nd so I put in another 4T40E transmission from a sunfire cleared the codes and they are still popping up. I am going to replace the wiring harness and the PCM. My car has ABS and that damn Traction Control. So which one will work.
I am thinking of just buying another motor and transmission but that is out of my budget right now.
Thanks for replying if anyone does.
Is it possible to get a PCM that will work with my 2001 LD9 and bypass the traction control. I live in CANADA and the winters are brutal -50 Celcius in Janaury. Traction Control won't let me get out of ruts or deep snow so i get stuck all the time.
HELP!
Replace it with the same model that's in there now.
Ok, good enough for me. thanks
