Help I'm working on my neighbors 2002 2200 cavalier no codes stored on the computer. The car will not start. I'm getting spark, fuel pump is priming, and the crank case vent is puffing out air like it should if the timing chain is ok.  I probed a injector connector and during start up it was at 1.5v.
I'm going to try the probe later on with wire to make sure I thought they should be 12v.  If it's still 1.5v what should I check next?  What sensor is in charge of controlling them cam position? Thanks.
do you have 12v at the batter and does the fuel pump prime
JBO since July 30, 2001
If you have checked fuel pressure and it is good (dont care if its priming doesnt mean the pump is good) and also a crank position sensor may do that....... One time  I experienced in a rare case the wheel well was missing on the right side and the pcm was corroded and had broken pins
Erik Packard
Yes battery is brand new.  And yes the pump primes.
Ricozero wrote: One time  I experienced in a rare case the wheel well was missing on the right side and the pcm was corroded and had broken pins
I THINK in 02 the PCM was moved to the passenger side strut tower.
So it cranks over fine it just won't fire? Does it sputter at all and try to start or just keep cranking? How did it stop running? It just wouldn't start one day or the person was driving it and it shut off? Like said check the actual fuel pressure.
"In Oldskool we trust"
