2000 2.4 manual dash harness. Im unsure on where these plugs go.
Here I need to know where the white connector goes, black and orange wire. The black connector pictured goes into the 2k cluster, the white one, no clue.
This connector im pointing to is apart of the harness that has the  turn signal/ wiper connectors. Its little, has 4 prongs. It has 2 grey, 1 blue, and 1 pink wires.
And is this the cruise control stuff? It goes in that empty hole pictured on the clutch pedal. If im not using cruise, It doesnt have to be connected does it?
Thanks all
2012 numbers - 4SPD
AUTOMATIC!!
First one is cigarrette lighter.
Thats my contribution
Lol thanks, as a non smoker that never came to mind ha.
The clutch pedal bracket has three sensors.
The one for the park neutral safety switch has 12ga. leads.
They are very big, you will notice a difference, keep these.
They are up higher inside the dash.
The other one with small wires, 16-18 ga, will be for the cruise control kill switch.
This is not needed if your not running cruise.
Are you doing a swap?
Yep I already got everything connected including the park neutral switch, what I dont have is connected.
Yep doing a 5 speed swap.
The last one, the white wire controls the brake lights... so yeah, you need that.
I believe the second one is for the cruise control on the lever... I am not exactly sure since it has been quite a while since I had my turn signal/wiper controls apart, but there is a small connector that goes to it.
John, does it matter which one of those open holes on the clutch pedal I put it in pictured behind it?
Lafonjef, I also thought of that as well. Thanks.
Doesn't matter which one you put it in, but the plastic plugs will only fit one or the other as they're a different size from each other (if I recall correctly). It's been a while since I did my swap and I honestly don't remember those details. I don't even have a manual J car any more to look at
Ohh I think your right about being different sizes. I will work on the car tomorrow so I will for sure check.
Thanks all, you all win!! LOL
The second one is for the cruise control on the turn signal lever, is consists of the power feed, cruise on signal, set/coast, reset/accel.
"United by Individuality"
"If life is a joke, why aren't we laughing?"
"Normality depends on one's perception of reality."
http://www.cardomain.com/ride/3820803
