98 Z24 rough idle,,,missing. I can hear it missing up to around 2000 rpm.
-Codes for down stream o2 and # 2 cylinder miss
-Changed plugs,,,all looked good and o2,,,,,cleared codes
-car still missing / rough idle,,,,#2 cylinder miss code again
-Swaped out coils and boots with my other Z that runs fine,,,,,cleared codes
-Car still missing / rough idle
-Compression check shows 130 - 135 psi on all cylinders
So what next,,,,,injector??
Also note that the traction  control and abs have been acting really goofy. Somtimes the low trac light will come on even at a stop. Somtimes it comes on when I'm taking off from a stop. Though I do believe this is due to the fact that the car is idling really rough. If i click up the e-brake it turns off then no more problems.
Thanks
Bob
Have you checked the EGR valve ?
Check wiring to cylinder 2 injector and if no power is present ive had pcms be bad with just one misfire caused
Erik Packard
have you compared all four plugs to see if they are the same color on the ceramic insulator?
dennis
vacuum leak between maf and throttle will cause all kinds of issues and code to set
an exhaust leak will wreak havoc on 02 sensor signals info as well
trac/abs has nothing to do with engine and engine codes and malfunctions
-96 cavalier 2.2 auto 143k miles
