what is the oil pressure supposed to be on a 98 cavalier 2.2.
Cuz my is on 10,or 9 psi, warm idle.
And when im on the highway it 65 psi
So can anyone help plz
10 PSI PER 1000K RPM IS IDEAL
Bobby  Higgins wrote:10 PSI PER 1000K RPM IS IDEAL
Truth!
-MD- Enforcer wrote:Bobby  Higgins wrote:10 PSI PER 1000K RPM IS IDEAL
Truth!
10 psi at a million RPM? Seems a bit low to me.
I see wut u did there lol its 1k
*****BLAME IT ON THE ALCOHOL*****
at 150º F 56 psi at 3000 rpm.
around 4-8 psi at idle would be fine and safe, when hot
doesnt need to be high
most oil pressure senders and guages arent very accurate anyways though
as long as you have some kind of pressure at idle then it be fine
especially if no tapping/ticking, or worse, noise
no ticking other than normal injectors ticking that is
-96 cavalier 2.2 auto 143k miles
