This is my son's car and he tells me that it will engage only 1st and 4th gears and he believes it is the shift linkage?!?!!?? I am a complete numbnuts when it comes to cars so I'd either like it to go to a good home or maybe barter for some repair help. Please find car details below:
BLACK 1999 CHEVY CAVALIER Z24 2.4L DOHC ENGINE
MANUAL TRANSMISSION
200K+ MILES.
CLUTCH REPLACED @ 100,000 MILES
WATER PUMP JUST REPLACED
CATALYTIC CONVERTER REPLACED @ 180,000 MILES
CYLINDER HEAD GASKET JUST REPLACED
TIMING CHAIN JUST REPLACED
MINOR BODY DINGS / SCRATCHES.
GOOD CARPET, NO TEARS, DAILY WEAR
AFTERMARKET CLEAR HEADLIGHTS AND CARBON FIBER TAILLIGHTS
EIBACH FRONT AND REAR SWAY BARS
UPPER AND LOWER ENGINE MOUNTS
2.3 HO INTAKE MANIFOLD
59MM THROTTLE BODY
MAGNAFLOW CAT BACK EXHAUST
MILES ARE ALL HIGHWAY. GETS ABOUT 30+ MPG!!!
35% TINT FRONT TWO WINDOWS
20% BACK AND REAR WINDOWS
COLD A/C
NEEDS SHIFT LINKAGE?
OFFERING on J-BODY FIRST BECAuSE I'D PREFER THE CAR GO TO AN ENTHUSIAST OR
GET SOME HELP TO FIX!!
Where are you located?  Also, it is the shift linkage or the pin that goes into the transmission, broke.
Thanks for replying......I'm in East Windsor, New Jersey (Central).
Unfortunately, I have no idea what is broken - his friend told him it must be the shift linkage since he can only get it into 1st and 4th. Not sure if they looked extensively for a cause.
Remove the center and u will see the 2 cables there thats where mine broke if those look good then look right on top of the tranny and see if those r connected
*****BLAME IT ON THE ALCOHOL*****
