I'm collecting all the parts/info I can get to start my 3.4 swap...  but reading online the 96-97 3.4l had the most power 200-210, is that the best engine to swap into my 03 Jbody?? I already read up on the trannies and such, I need the OHV 5spd.... and i'm going to get the motor mount swaps from a member on here...  I'm just looking for the most powerfull 3.4 i can get for the swap and keep it somewhat simple.. is the 96-97 the same amount of work to swap over? or do you have any other sugestions on this?
That 200hp 3.4 is a DOHC engine. Completely different animal than the 3100/3400.  It's been done, but required significant work to the car. Get a 99+ 3400 and you are starting off around 185hp. A little work will get you over 200 no problem. Spend some time on 60degreev6.com and you'll see what can be done.
A cam swap, some decent headers and an exhaust will easily net you well over 220 hp. I know of a few mild 3400s that are pushing well into 250whp range with barely any real work done.
colt45 wrote:A cam swap, some decent headers and an exhaust will easily net you well over 220 hp.
Good advice. These engines have a ton of potential without even getting into the block. Personally, if you have some cash to put into it, I might look at doing a 3500 head swap and some higher compression pistons (the 3500 heads will lower your compression a little, but even without compensating, the flow gains are worth it).
mmmm...... 3500 top end swap.
really gotta get off my ass....
yes you should
hahaha
remember just cause it was used in a car or van doesn't mean more power full engine its the same engine just done in tuning.  you could do the 3500 heads and the 3400 f body pistons and rods and a cam.  mods are endless and depends if you wanna get crazy
JBO since July 30, 2001
NOTa2_4 wrote:... you could do the 3500 heads and the 3400 f body pistons and rods and a cam...
Hello 12:1 compression. LOL. Not very practical. Better off getting aftermarket pistons with just a smaller dish than the factory ones.
hahaha you say it like anything we do is practical hahahaha
s homer simpson once said IF  YOUR GONNA GET MAD EVERYTIME I DO STUPID THINGS MAYBE I SHOULD STOP DOIN STUPID THINGS
