I did my eco swap a few years ago and everything was fine.  I built a new engine, on start up the car ran for about 1 minute and stalled.  Has not started since.  I have fuel NO SPARK.  I replaced the coil, ICM, Crank sensor, and ECM, same results.  Any suggestions...
Theft light comes and goes after a few seconds.
It will come on with the turn of the key then go off shortly after...
Check crank sensor and ignition pulse, should be getting trigger pulse to the icm. If you have a scan tool check cranking signal, that should rule out the crank sensor.
