I would like the diagrams for the 2002 2.2 PCM (Mini one that is mounted on the strut tower and the BCM that is mounted in the driverside kick panel.
The PCM is marked 12218903 Delphi Automotive Systems *86DPSJM12007AFUJ* (SERV NO# 12210553)
The BCM is marked 22689179 Delphi Automotive Systems BCM *879178S113302911*
Pin-out's perfered, but can use anything you have!
You looking for a specific circuit?
P&P Tuning
420.5whp / 359.8wtq
not really, car doesn't run due to a bunch of wiring issues and I want to remove some stuff. gotta tidy up! Id just like the whole pinout, because there are alot of wires that are the same color... expecially green's and purples.... haha
purples are either used for ignition feeds (sometimes) but mostly serial data lines
pinks are 12V ignition power
orange are 12V battery power feeds
dark greens(with or without white stipes) are a sensor signal line
can't post pinouts at the moment sorry
JBO since July 30, 2001
Go to Autozone.com and make a little account, then get the wiring diagrams from there. I think you can still get them there. At least for the PCM you could anyways.
