So my 98 Sunfire has a check engine light on, I tried to connect my scanner to it and it says that it can not connect/not available, I have tried the cig fuse and still nothing any idea's?
I've seen someone post here before about it.  They found another fuse that was out, but I can't remember for the life of me what fuse that was.  Maybe look through them and see if you find one popped.
I will double check but im about 99.9% that they are all good....
ground to the obd port may be loose, thats what happened to mine!
horn fuse.
Sponsored by:
Kronos Performance
think 98 the horn was in the cig fuse my 97 was if i remember corectly
JBO since July 30, 2001
NOTa2_4 wrote:think 98 the horn was in the cig fuse my 97 was if i remember corectly
you do remember correctly.
check cavity 4 and 5 for ground and 16 for b+
It's dumb I know, but make sure the key is on?
port 16 should be 12volts
4 & 5 are grounds (ohm out 4 to ground and 5 to ground see if its open if it is fix it)
then check to see that your getting 12 Volts on 16
data link port is powered of the horn fuse FTR
