hey all, I just picked up a cheap 99 sunfire 2.2L tonight. in over all really good shape, just gonna be a commuter for now save some gas money. but anyways when I test drove it it ran great no noise or anything, then on my way home started hearing a knocking, getting worse as she warmed up, when she's cold there's nothing but as she warms up it gets fairly loud. I'm thinking it's a rod knocking just going by listening to video's on youtube but haven't had a chance to really look it over yet. what's the best way to narrow down what is causing the noise? If it is a rod what's the opinion on fixing? better to rebuild the motor or head to the junk yard looking for a replacement?
from what i gathered on this site the 2.2 motors are pretty common to throw the #3 rod bearing. if the knock is interrmitten at the moment i would quickly replace the bearings on the lower end. and while your in i would do all rod as well as main bearings. also check the lifters i believe the 2.2 uses hydraulic lifters and those tend to go out over time as well and when they go they too sound like a spun bearing.
SHOoff wrote:mike  lyons wrote:from what i gathered on this site the 2.4 motors are pretty common to throw the #3 rod bearing. if the knock is interrmitten at the moment i would quickly replace the bearings on the lower end. and while your in i would do all rod as well as main bearings. also check the lifters i believe the 2.2 uses hydraulic lifters and those tend to go out over time as well and when they go they too sound like a spun bearing.
Fixed!
double fixed.
I would rebuild, that way you know whats in your engine and you know it s brand new. Who knows, you pick up a junk yard engine and it could throw a rod 20 miles down the road too.
Sponsored by:
Kronos Performance
hey the sunfire is actually a 2.2. the other thing about rebuilding it is it has almost 300k kms on it so it's gettin pretty high in mileage, thinking i might be better off picking up something with less mileage
