[*] I have a 95 quad 2.3 5spd man. Cav I want to swap in a 2.4 with a getrag trans or an izuzu whatever what will I need for the swap? Can I use the 2.4 engine harness and pcm. Also will I need the cv shafts or anything else? And can I use the 96-98 body/light harnessor will I have to keep the 95 harness?
The 2.3 is a better motor than the 2.4, well as far as the oiling system goes. 2.4 doesn't like the number 3 rod bearing so much.
Oedwards wrote:The 2.3 is a better motor than the 2.4, well as far as the oiling system goes. 2.4 doesn't like the number 3 rod bearing so much.
The 95 2.3 has the same crappy oiling system as the 2.4 does.
The 2.4 will bolt to the 2.3 5spd since they are the same trans.  Also you should be able to run the 2.4 off of the 2.3 wiring and ecu.  There might be little things like connectors and such that will need to be swapped but it should be a pretty easy transition.
everything but the knock sensor and cam sensor will work on the 95 ecu and harness just did it to mine to drive it while 2.3 gets built
