How hard is it to remove the gauge cluster on a 2005 Sunfire?
Don't know if it's clear but you do the above and pull the now-exposed cluster straight up.
The dash in the instructions look like '02 and earlier. Is the '03 + dash the same as the earlier version???
Yes, BTW it isnt that hard.
It only takes about 15 minuets once you know how to do it. Basically, It is not that hard but you will break something if you do not know for 100% where every nut and bolt is. Be Carefull!
I miss my Cavalier, even if it made 100 hp on a cold day and had more suspension then it deserved.
could always look into downloading the manual that's posted in the sticky portion of the exterior forum......or buy a manual...either way it's fairly easy.....10 maybe 15 minutes tops.....
2003 Cavalier
Stock 2.2 Liter, 5 speed
" Leave the rice to Uncle Ben's and the wings to KFC..
Go clean or go home. "
