Anyone have a quick how-to that shows how to change out front blinker bulb ('97 Z-24)?    I couldn't find anything when I tried to search.  Thanks in advance for the help!
2009 Honda Accord EX-L V6
2005 Pontiac Grand Prix GXP
1997 Chevy Cavalier Z-24
1988 Merkur XR4Ti
serious
either rear it from below or the eaiest is to take out the headlight if you can't do that how do you fill it up with gas
JBO since July 30, 2001
I just picked up the car for a winter beater and I didn't look at it in very much detail at all, I just saw that there weren't any screws in the lens itself  and it didn't appear to be accessible from below....and instead to pulling off unnecessary @!#$ in 15 degree weather I figured that I would ask a quick easy question.  Sorry to offend you with my question and thanks for the warm welcome to the forum.
1988 Merkur XR4Ti
Here you go,open the hood,Then you will see a plastic cover,Remove plastic clips I think there are 6 or so,Then you will see the head lights,Remove the 2 bolts that hold the head lights in place,then lift head light out,then you will see the back of the bulbs and just twist and it should come out,And then just do everthing in reverse and enjoy your new bulb.
takes 20 minutes at most
Thanks Jason and 99redz24.  I got it done in about 10 mins. once I knew i could get to it by removing the headlight!
1988 Merkur XR4Ti
Last time I got the oil changed they could not figure it out so after 20 minutes of them staring at it they finaly said enought and then gave me a discount for not being able to change it. Went home and figured it out myself in about 30 minutes.
Don't forget to change you blinker fluid!
The ones in the bumper are a bit more harder to get at.
Proud member since 99
