HELLO TO ALL IS IT A TASTE TO KNOW THAT THERE EXISTS A GROUP OF PERSONS THAT HAS THIS CAR AND THAT A FORUM EXISTS FOR THE CHEVROLET CAVALIER, I GREET HIM FROM GUATEMALA, MODEL NEEDED HELP WITH MY CAVALIER Z24 CONVERTIBLE 98 I HAVE A PROBLEM WITH THE BONNET IT NEITHER RAISES ME TO REMOVE NOR LOWERS THE ITENTO TO ME BUT AS WHAT CURRENT DOES NOT COME TO HIM I DO NOT THINK WHERE DOES THE RELAY GO?? OF THE BONNET OR SOME FUSE OR SOME ELECTRICAL DIAGRAM THAT HE SAYS TO ME WHERE TO GO AWAY NEEDED HELP THANK YOU.
WHAT DID YOU JUST SAY!?!
Edit: due to bypassing of language filter.
Edited 1 time(s). Last edited Monday, September 06, 2010 2:09 PM
I feel like there might be some type of language barrier here..
eat da poo poo
i think his convertible top (bonnet is normally a trunk for other countries so i could be wrong) won't go up or down.  he doesnt know whether it has lost power (current) or a fuse is blown.  but i know nothing of convertibles so i'll leave that problem for yall.  i would say it's the motor mechanism itself if i had to guess
I believe boot is the trunk
Bonnet is the hood.
aver amigo de guatemala. yo hablo y entiendo español... escribe tu problema en español y yo lo traducire en ingles para ke otros entiendan..yo tengo tambien un convertible de 2 puertas. No uses traductores como el ke usastes.. no se le entiende nada.. bueno gracias y espero tu respuesta... desde Mexico/Estados Unidos.
since yo no hablo espanol, is he saying that his top wont raise/lower and he wants to know how to troubleshoot it with a wiring diagram or where to replace a fuse?
have him look here first for plenty of vert info.  not sure what to tell him if he cant understand the instructions, but its a start at least.
alberto:  buenas suerte amigo
(tabs) wrote:since yo no hablo espanol, is he saying that his top wont raise/lower and he wants to know how to troubleshoot it with a wiring diagram or where to replace a fuse?  have him look here first for plenty of vert info.  not sure what to tell him if he cant understand the instructions, but its a start at least.
gracias amigo buena onda!!!!! que bonito tu cavalier
i wonder if he used an online translator?  those things suck so bad.  if anything try using the manual over ride until you get the relays or motors replaced.
A sunfire at work had this problem, the motors would turn but the shaft would just spin in the gear. we could have just welded the gear to the shaft, but seeing how I work at a garage, we just replaced the motors.
Godspeed wrote:WHAT DID YOU JUST SAY!?!
ahahahahahaha
Exacto haz click on ese link ke te dijeron ahi hay mucha informacion sobre la capota.
and yes.. your correct (tabs) he saying what you said. Hes convertible wont raise/lower like is not recieving any current. and he wanted to know where the fuses or how to trouble shot.
Un traductor que funciona bastante bien aqui el link
http://tradukka.com/ si no funciona el link buscalo con google
Saludos.
wtf wheres the press 1 button for this tread.
bluedriftcavy(a.k.a. wayne) wrote:wtf wheres the press 1 button for this tread.
i was looking for the closed caption options.
Omg I think I just tinkled myself this is ,.'"#*?!/+@ funny those translating websites SUCK
Modding my j since I found the org
