ok both of my cavaliers the blower only blows 2 speeds. My dad already fixed the one once and now its broke again. Anyone else have this problem? its either no heat or ac at all or full blown...
If it only works on high then I would vote either the resistor block or there is a couple grounds on one the bell housing bolts toward the front, check them.
When I did my 3100 swap my blower only worked on high and it was because I didn't have that ground hooked up.
This belongs in maintenance. Also if you posted there you may have noticed the first sticky is called : HELP! MY LOWER BLOWER SPEEDS DONT WORK!
D.Simoes wrote:This belongs in maintenance. Also if you posted there you may have noticed the first sticky is called : HELP! MY LOWER BLOWER SPEEDS DONT WORK!
thank you Mr. Mod
ok sorry for posting where it shouldn't be. Its a 3rd gen question thought it was about anything
