hi guys, i got a 05 cavi with ecotec and i had it for a little over a month and i love it so far! but lately its been doing something weird with the clutch pedal, sometimes when you let off the clutch pedal when its almost fully let off it (fully up) , it feels like the pedal is sticking a little.  it only does this sometimes for the most part it doesn't.  the guy i got the car from said he just replaced the clutch last summer from the dealer, but whether he did or not i don't know as he also said he changed the oil when the oil was black and below the add line and the oil filter was broke.....
back to the current problem though,  i was wondering if this clutch problem is something i should worry about or not, it doesn't slip or anything, the car doesn't get drove as much...but it sits around for a maximum of 3 days.  it has 112,000kms.  thxs in advance for any help, shawn
Could be the throwout bearing? If the guy went the cheap way and only replaced the clutch without replacing the throwout bearing and machining the flywheel. Just a thought , but i have seen this many times at my workplace over the years.
Maybe a master cylinder starting to go bad.  It happens.
lol my cluth i thought the same thing till i moved my floor mat hahaha
