On my 2004 cavalier I get nothing.   Is this the flasher ?  Where is the flasher located?  I have replaced flashers on other cars and never been too much of a problem but I can't seem to find it on this car .
Flasher is a bright green little plastic cube, mounted up behind the dash at the top of the accelerator pedal's metal brace.
John Lenko wrote:Flasher is a bright green little plastic cube, mounted up behind the dash at the top of the accelerator pedal's metal brace.
OK that is what I thought.  I  bought a new one and still nothing.
Did you check the fuse? I had this same problem on my car. I found an exposed wire on one of my front turn signals causing it to short out and blow the fuse.
lafonjef wrote:Did you check the fuse? I had this same problem on my car. I found an exposed wire on one of my front turn signals causing it to short out and blow the fuse.
Yes I checked the fuse.    Which is what it turned out to be.   I pulled the fuse out to see if that would fix my fan switch would not come on( which it did) and forget to replace the switch.   Sometimes I feel so stupid
