The l61 and le5 eco radiator hoses are interchangable, though I wouldn't trust ebay on that being the right product...I would check out OBXs website and first see if they even make a kit for ecos.
but the le5 is not a engine option for the cav... hence the confusion on the listing. thats why i asked to see if someone had experience with them, since obxracing does not have silicone hoses listed on their webpage
ʇı ɹǝʍo7 | ǝcoMonstǝrs
Fluffy wrote:but the le5 is not a engine option for the cav...
I realize that. What I am saying is that the le5 radiator hose is the same as the l61; so if that hose on ebay is indeed design for an Eco (and not an ld9), it will fit a L61 or Le5 (maybe even an LSJ).
I'm guessing since it specifies 2.4, its for a ld9 and the vendor just has the wrong year listing...maybe call OBX for an actual answer?
Torres @ SpeedZone wrote:^^WOW
Hmm, I smell a little sarcasm in that wow...
 just messin of course
Umm, this is the .ORG...no messin around allowed!!! Haha
And back to Fluffy..I would just save yourself the hassle  and call/email a sales rep from OBX and get a straight answer from them if they even make an Eco hose it. We all know how reliable Ebay can be, lol.
I've bought from that seller before but it was for my 2200. I emailed the seller and asked I was just wondering before I had to cause I didn't know if he is competent
just throwing this out there but i have the OBX silicone hose kit for my 2.4. all it has done since i installed them is piss coolant out from every single clamped spot. no matter how tight the clamps are. drips from both rad hoses, water outlet on the head, the metal pipe that runs under the motor and even from the coolant res. i see little puddles under my car wherever i go. i'm going to be switching back to regular hoses sometime in the near future. i do not reccomend them.
must be a 2.4 thing, fluffys 2200 worked great
Jon D wrote:just throwing this out there but i have the OBX silicone hose kit for my 2.4. all it has done since i installed them is piss coolant out from every single clamped spot. no matter how tight the clamps are. drips from both rad hoses, water outlet on the head, the metal pipe that runs under the motor and even from the coolant res. i see little puddles under my car wherever i go. i'm going to be switching back to regular hoses sometime in the near future. i do not reccomend them.
are you using the stock spring clamps? Im just curious because we have had issues with a freinds car and silicone coolant hoses as well. We ended up going with some stainless clamps you can tighten and it worked great.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
i switched to stainless screw clamps a little while ago all around. still leaks.
 might just be a @!#$ set.
that sucks, i loved the set i had for my 2200, i had screw clamps on it never leaked. in fact i even made hoses for the heater core hoses because they worked so well
