I'm going to be running a oil temp gauge on my 3400 grandam engine. Does anyone here know where I would install the sensor on the engine? Did a quick search on a grandam site and got nothing. I'll try looking somemroe but if someone here could help me out I'd appreciate it.
You might be able to get yourself a little T and run it at the same spot as the pressure sending unit.   Would be my best guess to keep from having to drill/tap the block.
Thanks for the info. Can anybody confirm that this is the best way to do this? It sounds easy enough but I just want to be sure.
Are you going to be using the oil pressure sending unit? You could put it in place of that or there is also a small plug where the oil filter goes and install the sensor in place of the plug.
C:\Users\Phillip\Pictures
^^^^^ thats wat i did for my pressure gauge. i need to use a nipple and a 90 but if its for temp the sending unit is alot smaller.
I agree with both the above statements. You have some options.
3400 SWAP DONE. 187WHP 212TQ (14.2 @100MPH NA) 240WHP 310TQ (N2O)
Thanks for the suggestions.
I also had similar questions. Is that little plug there on the 94-95 3100's as well?
Shoot I was at the junk yard today and would have checked lol
