earlier i posted the problem that is annoying thread to see y my car was revin up and back down continuously at a stop. so i replaced  the idle air control valve and it fixed it for a couple days. well it started back up and it got really bad. so i took it to a garage and had them take a look. turned out the the front strut bar was hitting the sensor and unhooking the sensor. so if you have a problem like this on a cav from 95-99 then this could be why your car is doing this.
I know the IAC only uses two bolts... Is it possible the flip it the other way?
That's why on the 95-97 2.2 cars you use the GM STB.   98+ the TB is moved down so you don't have the problem.
Never heard of that problem with it hitting some wiring. Interesting.
3400 SWAP DONE. 187WHP 212TQ (14.2 @100MPH NA) 240WHP 310TQ (N2O)
im not sure if you can flip it. i never heard of that problem either. it sucks cuz now i have to find a bar that will not interfear with it.
I would try to just flip it around before I bought a new strut bar... but that's just my cheap ass talking.
I bought a cheap strut bar for the womans 95 Cav and it rubbed the harness out so I bought a vert bar from the junk yard. Definately agree with SHOoff, get a vert strut bar.
C:\Users\Phillip\Pictures
