Hey guys, 2.2L. I just realized my fan is always running while the engine is running. Even is the water temp is cold. I replaced the coolant temp sensor twice but no go. What else tells the fan to turn on??
thanks!!
^^^what he said
if you have recirc the circular arrows will also bring it on
JBO since July 30, 2001
My 97 daily does this as well, fan comes on when the engine is running. No CEL, no a/c input, changed relays etc. Mine must have a short to voltage though because it seems as if it runs about half as fast as it should.
If yopur car has the check engine light on, thats probably the issue. For certain codes in the pcm, the fan defaults to on.
check the pig tail to the engine coolant temp sensor they usually break the wire insid my 1997 cavi did the same thing
MEAN & GREEN.
a/c off when you press your ac button inside the fan is supposed to kick in to help with the added load.
MEAN & GREEN.
