Did all the research on here hopefull will be doing this swap in a month or so.Was debating between the 2.5,I have 98 cav 2200 5 speed.As I have read tranny will work,Ill need a cluth engine wiring ecu,Mounts and Fabracate a bracket or fewand a cluster?My question is about suspension and axles.Do you need to do anything with them?And do you need the Converter off the other car for exhaust thanks!Any tips would be helpful too!Would I be better off with a 2.4 swap or should i go ith this!
Go with the 3400. The tranny stays the same and the axles do as well. Any more questions PM me.
3400 SWAP DONE. 187WHP 212TQ (14.2 @100MPH NA) 240WHP 310TQ (N2O)
don't need the converter of th other car but just do a 2.25 exhaust with high flow cat your set
JBO since July 30, 2001
Thanks a mill guys  looking forward to this hopefully I can paint it afterwards if the funds are good! will Pm you nate if I get stuck won't be starting it probly till march
Dont be like all these other people that say there "gonna do it" JUST DO IT! Its great.
yeah I'm looking frward to it just not sure when in march its gunna begin,My truck just cost me 350 bucks so that took out of my engoine fund
 haha whats the worst part the wiring and comp?
wiring is the hardest part
2 options
convert your interior wiring and stuff to a 2000+ run an impala 3400 program on the PCM and then you can use the 2000 factory gauges
or
use  98 Oldsmobile silhouette PCM and do an autometer setup.
this option might cost a bit more money since the gauges aren't cheap but if you use the 98 PCM from a silhouette it has NO VATS where as the impala PCM will have to have that turned off, either way you will want HPTuners to remove the auto trans stuff
awsome I priced everything from junkyards other day but they all cut the wiring harnesses around here,trying to find a smashed up car
he's a great seller, and fast
awsome,seems like that was going to be the hardest part to get,So he seems only to have the monte carlo 3400 wiring, Id need the Monte Carlo ECU but any 3400 would work right?Sorry if that sounds stupid a mechanic Haha,A retired mechanic is doing the swap for me down the road for me when I get everything Im gunna help him with what I can though. Thanks
NOTa2_4 wrote:wiring is the hardest part
2 options
or
Sorry to bring this from the dead, but is that right? Can you get the PCM from a Silouette and run aftermarket guages? No Theft or manual transmission issues?
if u get a 98- pcm i belive it dosent have passlock and thats why its recomended. using that the motor should run but would be way beter with a tune for manual trans and wat not.
2 options
or
F*CK all that.
For a manual transmission car doing the swap.  Keep the stock PCM and electronics and piggy back in a Megasquirt.  Save time, money, and effort.
The harness for my engine is separate from my body harness.
i love how someone who has done an engine swap posts what to do and someone turns around is that true will it work
YES IT WILL WORK I WOULDN'T SAY IT WOULD IF IT DIDN'T GEEZE
theres so many ways of doin it.  i started my 3800 up with a 3400 silhouette PCM cause i had theft issues shut it off right away after it ran cause the crank sensors are different 1 is 18X 1 is 24X but thats cause all i had was that PCM ps for the note car did run hoibly when doin that.  don't do it unless you know what yoru doin
