I checked the relay under the hood and it is working.    I pulled the fan and put straight power to it and it comes on.    I guess maybe it's the switch that is bad ?
does it come on in high? blower motor resisters go all the time in cavs
ray gardner wrote:does it come on in high? blower motor resisters go all the time in cavs
No it doesn't come on at all.   Were is the resistor ?
The resistor pack is right next to the blower motor.
I'd start by seeing if you had 12V leaving the fan switch
Does anybody know if you can replace the switch by itself ?
Yes but it's never the switch.  It's the resistor.  It's right next to the blower motor.
2000 Ford F-250 7.3 Powerstroke 4x4 - Not stock
1973 16' Tahiti Speedboat
1983 200 HP Mercury BlackMax
1997 Chevy Cavalier with 275K miles
Zaairman wrote:Yes but it's never the switch.  It's the resistor.  It's right next to the blower motor.
My fan doesn't come on at all unless i put straight power to it.  I thought it if was the resistor the fan would come on but only stay on high ?
just test things in the circuit.  on your meter put the black on ground and the red at the fuse, and the switch and the resistor and then check the ground side, and the switch and you'll find out what it is
Check the hvac fuse in the inside fuse panel.
SLO CAV (the autoxing one) wrote:Check the hvac fuse in the inside fuse panel.
I did check the fuses.   I should actually clear this up.   The switch panel has power and come on and I can turn it a/c and the a/c comes on but it won't kick the fan on.
So now that I have corrected my question,  does anybody have any ideas ?
