i got a dog bone style 3100 motor mounts to rad suport can i swap to accessory side motor mount like the cavys use the motor runs good and i like to use it but was un sure on what i need to use in in my car
ill try to make this a litter clear on my ?
my problem is the motor has dog bone style motor mouts that bolt to the head and the upper rad support and i need it to be a accessory side motor mount set up is there a way to convert this motor over to accessory side motor mount and what all will i need to do this
Use the motor mount for a 99 Grand Am w/ 3400.  I'm not sure what all parts are needed to do that.   Probably be easiest to find a donor car somewhere at a yard and go over real well.  Perhaps ask on 60degreev6.com.  Tell them what year of car your engine came from, and tell them what engine it is, and tell them you need to swap to the mount that's on the 99+ Grand Am's.
After you find all that out, take my word for it and don't use the factory Grand Am Mount.   You'll break the piss out of them, I did.   Instead, get this and install it (though you need the baseplate from the Grand Am's mount)
http://wot-tech.com/shop/all/1999-n-body-billet-mount/prod_222.html
i got on 60*v6 and ask
i was told i had to add a idelr pully and i had to flip my belt tensioner over thats no big deal my fear is that the bolt holes needed to add the idelr and the motor mount are not there and ill have to get a new timeing cover
I'm pretty sure the timing cover is the same on both engines.  In which case you'd just grab the one from the Grand Am and it would be how you need it to be.
so i will need a timeing cover too
Quiklilcav wrote:SHOoff wrote:I'm pretty sure the timing cover is the same on both engines.  In which case you'd just grab the one from the Grand Am and it would be how you need it to be.
The only difference is the 3400 cover has the boss for the idler pulley near the AC compressor. Other than that, they're identical. The 3400 mount actually will bolt to the 3100 style cover. It's a two-piece unit. The problem is that the 3100 style accessory belt routing would interfere with the mount.
I'm pretty sure the Impala has a 3400 but doesn't have the idler on the timing cover tho, Stupid little BS that throws everything for a loop.
my 3500 cover had a mount for a pulley i didnt need and was in the way so i just cut it off.
