so I have a 5-speed that i cant hardly shift anymore, and have herd that the shift cables are prone to failure, my question is what are the symptoms of this? my 3400 supercharged cav is about ready for the track, but i need to be able to shift it faster than a dump truck lol.
3400 Ported m62 megasquirt.......gota love it
How much clutch fluid you got left?  From my experience the shift cables work fine til they break.  It gets hard to shift when you're losing the slave cylinder, and thus all your clutch fluid.  If you do need new cables, I believe you'll want the 2.4L cables because they have the heat wrap on them, for the exhaust coming off the rear.
Have fun shifting faster than a dump truck in that Isuzu transmission.
One of the shift cables in my car went bad once but did not break completely. It was very tricky to get it in gear and I had to do it very gently. If I didn't pull it into gear just right the frayed end of the cable wouldn't move the gear selector on the transmission (would only compress the metal strings in the cable itself) and I could feel it sort of 'slip'. It was only for 3 of the gears however because only one cable was like this, that may be a good indication it's in the cables.
However now my slave cylinder is going, which is very different feeling. It will grind gears a lot unless I pump the clutch really quick and shift immedietely after. Also, the fluid leaks out very quickly in mine, see if you can see fluid leaking out of the opening at the bottom of your transmission or somewhere else in the system. If it's in all the gears odds are it's a hydraulic issue IMO.
just disconnect the cables from the trans and go move your lever, if its still hard to move its the cables. Also check the cable jackets near the down pipe, my last set got hot a melted the jackets on them. I was hard to shift till they got hot again ant the melted plastic got soft again.
thanks guys ill check those things
