My friend has an '06 and the temp and fuel gauges suddenly started acting weird.  The temp needle is high and the fuel is low.  Even when the car is shut off the are in the wrong positions.  The speedo works just fine.  Do they need to be reset or something?
Car Off
Car On
Broken.
Buy new cluster off Ebay or JY.  Your mileage is saved on your BCM, so the new cluster will show your correct mileage.
mine did that at 80,000 miles but it was the speedo and the rpm and like they said its time to do the sunfire swap or the just get another cavalier one
2010 Lonestar Bash 2nd place J-Body Street Class
my step fathers 05 did the same thing with only 50,000 miles, gauges were acting all crazy. put in a used cluster and it is fine and shows the correct mileage
The gauges in my 04 are fine but the odometer numbers fade in and out.
Looking for something new? How about an off topic forum where you can truly express your opinions without interference of mods or admins?
Join verbalwarfare.com
http://www.verbalwarfare.com/forum.php?referrerid=86
Ronin J wrote:The gauges in my 04 are fine but the odometer numbers fade in and out.
smack your dash like it owes you money.
Rich Grayo Jr. wrote:Ronin J wrote:The gauges in my 04 are fine but the odometer numbers fade in and out.
i have to do that every once in a while
z yaaaa wrote:other than the nasty hood dent, steelies, 4X4 ride heidt, crooked front license plate, body color b pillar covers, 2200, lack of tint, and overall boringness of the car id say she's perfect!
Rahjee [rkm1989 wrote:]Jack Hogle wrote:My friend has an '06 and the temp and fuel gauges suddenly started acting weird.  The temp needle is high and the fuel is low.  Even when the car is shut off the are in the wrong positions.  The speedo works just fine.  Do they need to be reset or something?
Car Off
Car On
You have way too much gas in the car. Drain some out.
Actually its way too empty. Probably a blackhole or some dimensional void in the gas tank near the level sender.
Edited 1 time(s). Last edited Saturday, July 10, 2010 11:23 PM
you have an even bigger problem if your friends 06 is doin that
JBO since July 30, 2001
mine has been doing this for over a year...smacking it doesnt help. any other sugggestions? maybe its not plugged in all the way??
NOTa2_4 wrote:you have an even bigger problem if your friends 06 is doin that
A few 06 model J cars did sneak through.  Not may though.  Basically left over 05's taged as 06 cars.
My 2005 sunfire did this to me after a hard stall.   Looked crazy for about 2 days then went back to normal.  No problems since.
my temp guage used to act like that. I unplugged the BCM to do the DRL defeat and all is well.
mitdr774 wrote:NOTa2_4 wrote:you have an even bigger problem if your friends 06 is doin that
not according to GM they didn't they don't list a j body in 06 at all so really its an 05.  have a hard time finding parts for an 06 at GM
GM must have updated their computer system since I left the last dealer then.  they used to have a listing for a 06, and we had a sunfire that VIN coded out to be an 06.
