I need a pin out for the body side of the headlight harness.  I have looked and I can't find it for the eco car.  I have it in my Hanes for the 99 so I have it.  This would help me get my car done a lot faster.  Thanks to anyone who sends me some info.
lhave you tried looking for 2000-2002 models? they use the same harness as the 2003+
John the link says Apache Tomcat Access Forbidden
I have the dim beams.  Drivers side turn signals and parking light. no high beams no passenger side turn or parking lights.
The body harness is an 03 the headlight is a 99.  I have each plug and I am just putting them together.
have you tried my write up on the swap ?
click here
Sorry. Here's the 03 listing:
Pin    Wire Color    Circuit No.    Function    Pin    Wire Color    Circuit No.    Function
A    BRN    9    Park Lamp Supply Voltage
B    PNK    1200    Headlamp High Beam Signal
C    DK BLU    1201    Headlamp Beam - Low
D    YEL    1834    Front End Sensor Voltage
E    ORN/BLK    1140    Battery Positive Voltage
E    ORN    1140    Battery Positive Voltage
F    DK GRN    29    Horn Control
G    GRY    589    DRL Resistor Supply Voltage
H    RED    228    Windshield Washer Pump Control
J    LT BLU    14    Left Turn Signal Lamps Supply Voltage
K    DK BLU    15    Right Turn Signal Lamps Supply Voltage
L    BLK/WHT    1751    Ground
M    ORN    640    Battery Positive Voltage
N    ORN    740    Battery Positive Voltage
N    DK BLU    593    DRL Headlamp High Beam Supply Voltage
P    PPL    34    Front Fog Lamps Supply Voltage
R    DK GRN/WHT    1317    Fog Lamp Relay Control
S    BLK    251    Ground
S    BLK    251    Ground
Top line of each is the socket side, which I think is the headlight harness side. So the body side would be the second line. Well.. check pin N - if it's orange or dark blue, there ya go.
I think I got everything done but the high beams.  Mr. Lenko you are the man.  Thank you again!
wait so you didnt do the headlight harness swap?  so simple to do. easiest and best way IMO
No I am keeping my 99 lights.  Hell they have been sitting inside for 7 years they still look new lol.
so im still not getting it..  why dont you just plug the 99 headlight harness under the batter tray. save yourself some headaches.
99 headlight harness plug is different than the body side on the 00 or 03 cars. Won't plug in.
Yea I cut my body harness after the plug.  I cut the one from the junk yard after the body plug and spliced the 2 plugs together.  I posted a pic in my ld9 auto to 5 speed thread.   Which is done other than a main dash.  I drove it around over the weekend.
i plugged in my 00-02 headlight harness this past saturday onto my 99 harness. works just fine for me. lol
Lenko is going to disagree.  I am not the pro but my 99 headlight harness will not go into my 03 sunfire gt body harness.
Oops, I wrote that wrong. I meant to write the 99 and 01! are different from the 03. 99 should be the same as 00... It was 2001 that the connector changed to the later style. Same between 01 and 05... where the front airbag sensor is in with the headlight harness, instead of on its own.
what about my 96 cav? i also put a 00 harness for the headlight swap lol.  why did you pull the body harness?
When we have done a Ecotec swap into a pre 00 car and the owner wanted to keep the 95-99 lights we just hard wired the 00+ headlight harness to the 95-99 headlights. easy to do.
