Im looking at a 02 ls sport with a blown factory eco.  I happen to have a eco from 03-04.....What is needed to run the engine with the new style rail?
the only things you need is the rail, injectors, fuel pressure regulator, and the metal lines that run along the side of the head
Can I have the old rails and lines? DIBS!
if ur talking of removeing the 02 and dropping a 03+ engine in then all u need is to disconnect the rubberlines at the hard lines on the rail and remove engine. when u install the new engine with the newer rail then just plug in the lines and fire. simple.
awsome...thanks everyone!!
