i want to know if i can use the feul injectors and throttle body from a 2.4 on a 2200 sfi? is this possible ?
Mike Robinson wrote:i want to know if i can use the feul injectors and throttle body from a 2.4 on a 2200 sfi? is this possible ?
2.3 throttle body works with 98+ 2200 pre 98 you would need to custom make your own
Erik Packard
Ricozero wrote:2.3 throttle body works with 98+ 2200 pre 98 you would need to custom make your own
You are looking at making a whole upper plenum if you want a different TB on an older OHV..
