hell yes dan...keep up the good work..ill stop by tomorrow and check everything out while im out and about... im very excited about the eco swap and the 5 speed swap...
RIP JESSE GERARD.....7.11.87/1.25.08(sunfireboi)
You have received a forum warning:
Warning: Don't ever wish harm On an Ohio state player you Douche canoe...
Expires: Sunday, October 10, 2010 6:47 AM PT
Wooot woot  AUTO TRANS MOUNT IS A MOTHER FU&KER TO REMOVE!!!!!!!!!!!!!!!!!!
What did you do with your 99 body harness, engine harness, gauges, and PCM?
Do you want to sell them?
Looking forward to the end result. Are you using your 99 metal tank and evap system?
I have not gotten to the evap system yet.  I am not sure what to do short of swaping everything from the sunfire.  Am looking forward to some good advise.  Well, I got pissed off and cut the ld9 body harness.  But my buddy Ben has one.  As far as the ecu I have it but I think the bcm and Cluster are sold.
IT IS A GOOD THING I HAVE A MAN CAVE!!!!!!!!!!!!!!!!!!!!!!!!!!
IT'S SITTING IN IT'S NEW HOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Your 99 auto had a BCM?
Hey Enforcer do you want this tranny?  I am have a party saturday you can stop by get it party down with all of us check out what I've got going on with this car you can crash here and I'll sell it to you for $150 bucks.
No I got one for $50 with 52,000 miles on it....thanks though.
Let me know if the pcm and BCM sale falls through...
all I have to do is drill the holes for the clutch pedal and mount it and I can put the interior back together
Couldn't sleep with this on my mind.   Went and worked on the car not a thing wrong with the front end but I have something in  my eye again!
Can you get the GM numbers of the PCM and BCM for me?
Well well I started this little build on may 19th she is running on may 29th not to bad for working 40+ hours and taking care of a two year old.  I wont be moving forward for a few days at least I need wheel bearings and a dash and I think she may be ready to go.
i have a break line that is fuc&ed so just another set back.
95-99 do not have a Body Control Module (BCM). Only 2000-05 cars do. The 95-99 cars have a Convenience Centre module on the passenger side behind the dash, on the A-pillar, that does the same thing except for running the gauges.
The box in the spot behind the dash on the driver's side A-pillar... (with the "ETS" sticker on it) is the ABS module. And ABS is part of the brake master cylinder assembly on the 2000+ cars.
Wow, good job.  I was wondering at just how hard it would be to do a auto to manual swap.  Im seriously considering putting the 5 speed into my vert bc the auto is just way to sluggish, and its prolly going to go out soon anyways.  So idk, but good job man, keep up the awsome work.  Put up some pics of the car done and running!!!
I will still working on it.  The auto swap isn't to bad cutting out the auto mount is the worst part it was a bi*ch.
I have the new plastic fuel tank and pump hooked up and primed but no fire.  I hate the theft lock I have spent days working on it and even turned it off with HP Tuners I HATE GM!!!
Still nothing passlock I don't understand what I am not doing.  Does anyone know if I can do the relearn with a tech 2?  I'll take it to the damn dealer to get it running,
