So, I just recently bought a 2.2 eco engine, and need a few other things. I know what I need, and I know how to do the swap, my question is, will a 2.2 eco from an 03-04 fit a base 01?
I'm not going anywhere just yet
R.I.P. Jimmy "the Rev" Sullivan '81-'09
I read that, and posted there
I just wasn't sure, The guy at the junkyard told me not to buy it cause it wouldn't fit my car, and so did a few other people. I assumed if I got all the pieces I needed it would fit. I just wanted to make sure.
Ashallee (Deviant Isis) wrote:I read that, and posted there
Probably said this because this is not the motor your exact car came with soo no its not exactly a "direct replacement".. you need the engine harness/trans/etc... but the 00-02 the engine harness connects right to the interior harness... I posted that link, because that should clarify that, that is what needs to happen for any 00-02 J, specifically when yanking out an LN2 as well... aka your base model has an LN2.
Edited 1 time(s). Last edited Wednesday, March 31, 2010 8:04 AM
Ashlee you saw my car, It fits, I did the swap about 3 weeks og you shouldn't have any issues. Let me know. I have the same year as you!
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
Okay thank you
((Super))KbRedCavy wrote:Ashlee you saw my car, It fits, I did the swap about 3 weeks og you shouldn't have any issues. Let me know. I have the same year as you!
Duh **facepalm** you should come down and help me with the swap
Or see if that pick n pull near you has an auto tranny that'll fit.
Edited 1 time(s). Last edited Wednesday, March 31, 2010 12:26 PM
Yea actally it does, I don't how much they want for it, its in a 03-o04 red automatic cavy!
I've got 250 to put towards that and a new radiator.
You'd have to call them and ask them it as hit from the rear, its the car i got the lower motor mount bracket from
Could you give me the number? or the name and location?
PM'ed
Got it thanks, I just hope I can make it up there without my engine crapping out.
u didnt get the lower mount on the motor? the dog bone is the same i just did my a eco swap in my 00. you def need a upper motormount for the eco. oh since u are getting a diff harness then the one the motor came with be carefull and double check the chank postion sensor plugs match. they are soo close not even funny. that kept me from starting up since some one changed the plug on the new harness i needed and the old one had to be swapped in.
