I need to pull the SDM out of my car and it is not under the front pass seat. The car is a 97 LS 2.2 A/T. everywhere I look says its under the pass seat but its not.
Thanks much!
Sensor for the airbags.
Check under your center console/radio bezel. That area under there.
-Seth
It's bolted to the sheet metal under the carpet, under the passenger seat. Only on the 95's was it in the centre console area. Unless someone moved it there...
I looked under the center console, its not there. I Cant imagine its under the carpet becasue is looks like it contours the floor very well. I will look in back of the radio bezel tonight and rip the carpet up too.
Owner - LS Solutions.GM EFI tuning and controls fabrication.
Pro-Touring 71 Olds Cutlass, 364" LSx - 440rwhp - 11.55 @ 117 - 1.69s 60' - 22mpg - 3,850lbs
Short Track 97 Cavalier, massaged 2.2 and tweaked ECM
Lenko's right, it should be under the carpet.
No need to get all crazy with it though, just remove a threshold and a seat and it should give you enough room to look under there.
-Seth
Yup sure enough it was under the carpet, Thanks for teh help!
I'm stripping out a 97 so if anyone needs odd parts, glass, lights etc. email ryan.vanvels@gmail.com
