I have a 98 pontiac sunfire 2200 will a 01 chevy cavilier 2200 motor fit in my car?I am asking because I was told You Have to change the whole intake out put the 98 intake on the 01 and the same with the coil packs is that all that has to be changed or is there more and will it just bolt right in and will everything plug right back in like it was the old motor?
Thank You
98 and 01 are the same engine. The 97 and the 01 would be different.
Not sure about a few details like EGR setups and whatnot, but you should be able to drop it in.
www.gmscf.com
yea if they both have plastic intakes they should interchange. i would simply double check connecters as you have the old engine out, and change any that are necessary
