OK guys, I have worked out a deal for a group purchase on the billet offset upper mounts for the 3100/3400 V6 swaps.
Before posting the pics, and the price, I just wanted to reiterate why these mounts are the best (IMO) option for swapping the 60 degree V6 engines into our 3rd gen cars:
Complete 100% bolt-in. No machining necessary to any parts on the engine, and no custom mounting bracket, or modifying your mounting bracket, are needed. Just bolt this to the "Y" bracket on the front of the engine (for this mount, the 3100 accessory belt routing is necessary--very simple--see the sticky for more info on this), and it bolts right to your factory frame rail mounting bracket.
Use of the J-body eurethane upper mount insert, for a very tight mount, with little movement.
On to some pics and pricing:
Here are three finishes that have been made so far. The first one is bare polished aluminum. The second is clear anodized. The third is black anodized. Other colors are available, but there is one hitch to any anodizing: if the shop already has a batch of parts in that color, there is no charge. The batch charge is $100, regardless of how many parts they do. The shop typically does a lot of parts in black and clear, but occasionally does blue and red. If they don't have anything going out, and some of you want to get the same color, we can split the batch cost between you if you like.
Pricing:
(plus shipping, which is usually about $10 priority mail)
1-3 mounts $180 each
4-6 mounts $160 each
7-9 mounts $150 each
10+ mounts $140 each
If there is enough interest, I'll run this as a GP for four weeks.
So who would be interested in this?
Edited 1 time(s). Last edited Monday, March 23, 2009 3:21 PM
I would be on it but I just got one from you. And looks great.
sorry man i emailed u about it but its a little pricey right now i just spent 400 for my 3500 and 300 on a tranny.
In my opinion, people should not balk at that price-- this mount makes the swap an easy bolt in -- i probably spent 3-4 hours just setting up my raised frame mount. The hard work is now done!! bolt in and wire it!!
I want one and I dont care what color it comes in
