I have been reading  about all of you  guys doing the v6 swap and some thing came to me . You guys say  that it is better to use a stage II clutch  could a gen II v6 clutch  work to hold the power as well or no?  I have been thinking long and hard about the v6 swap talked  to a buddy of mine   about it and he says we should do it   i am just wondering  how long it will take and what is the hardest part of the swap.
97 2.2 5speed (2slow)
Since the V6 has near double the HP and Tq that the 2.2 has, the OEM clutch won't hold it for long... A SPEC stage 2 for the 2.2 will work just fine (at least mine has so far)
Hardest part: wiring
How long: Varies
thanks.     Do you  have  the 8 pound flywheel  as well
no, running a stock flywheel, lightened a little.  I've heard bad things about the aluminum flywheels so didn't want to risk it
I don't believe the V6 clutch will work on the Isuzu transmission.  I could be wrong on that though.   But even still you'll want a better clutch, since the 3400 (if you go with that) has 40 more hp and 25 more ft/lbs than the 3.1 in most cases.
also you will have the tranny out anyways, might as well put a stage 2 in, i got a fidanza light weight aluminum flywheel but only have driven it about 1500km  around 500kms hard so far so good lol  feels great though
what ever trans you use, use a clutch for that trans
like i have an 00-02 2200 getrag i got a clutch for that
wiring is the hardest part and is the key component to the swap
PS switch your cars interior wiring to a 2000+ then run the 2000 Gauges.  97 gauges wont work but a 2000+ 3400 with an 03 impala program will thats what colin is running
JBO since July 30, 2001
v6s are over rated do an eco swap j/k im looking into a cheaper clutch setup as well i dont have a 600$ to dish out at the moment
my kill list:a geo metro and a mac semi wow did i kill that thing
dish it its worth it or just buy a spec thats what i'm running mike and i have had no issues as of yet
