I noticed that when I hit a bump sometimes, or a series of bumps, my ABS will turn on and make the ABS noise.
It did it before and after I put new front suspension on the car.. 97 cavy coupe
Anyone elses do it?
99 cav 2.2L 212,000 miles
97 cav 2.2L 110,000 miles
91 cav 2.2L 236,000 miles RIP
04 Silverado Z71 Ext.Cab 55,000 miles
01 Suzuki SV650 22,000 miles
97 Arctic Cat ZRT 600 6,000 miles
yea abs kicks in during an instability and ours is very sensitive. braking while hitting a bumo means the front tires end up going slower than the rears as you hit, abs pulses giving you a vibration, perfectly normal
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
Yeah, there's a specific pothole near where I live that I can't avoid, and it's right in front of a traffic light. If I know I'm going to hit the red I usually brake a little earlier so I can let off for a second as I ride over the hole, and then I get back on them. It's kinda annoying, but I'd rather have oversensitive ABS than none.
there is a spot here that has rippled pavement. Every day it does it for 20 feet or so at 10 mph. Drives me nuts.
My girls cobalt doesn't do it.. its almost as if hers rides 10x smoother and the wheels are not leaving the ground at all on the bumps.
I'd say just brake a little early and cost through the rippled area. Either that or sell your car
yea its quite annoying, but now that I know its normal it puts my mind at ease.. lol
