I know someone with a 97 cavalier rally sport wit a 2.2 and it won't start we can use all the help
is it turning over or what is happening?
2000 Cavalier Sedan.
put some gas in it......
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
check the starter, battery, key switch, wires, belt, lifters, springs, shocks, seats, and anything else.
seriously, "it wont turn over" is still very vague. getting electrical power? when you try to crank it, does everything dim? do you hear a click? can you turn the belt by hand? does the fuel pump prime? really, it could be any one of about five dozen things at this point.
it gets power every where but the switch dont feel like it turns all the way
I think you found the problem.
They also told us it could be the clutch or somthing else
are you pushing that 3rd pedal to the floor while your trying to start it?
Infantry!!!
Yes we are we even compared it to my 96 z24
try push starting it. drive to a auto shop, and have them fix it. seriously,you aren't giving us ANYTHING to base an educated guess on.
is there any other way to try somthin with the safty switch on the clutch
Rich Grayo Jr. wrote:try push starting it. drive to a auto shop, and have them fix it. seriously,you aren't giving us ANYTHING to base an educated guess on.
how are they gonna drive it to a auto shop ?
azncav 2,4 2,2 wrote:Rich Grayo Jr. wrote:try push starting it. drive to a auto shop, and have them fix it. seriously,you aren't giving us ANYTHING to base an educated guess on.
if they're getting electrical power, but its just not cranking, there's a damn good chance you can push start it.
Miguel Rios wrote:is there any other way to try somthin with the safty switch on the clutch
on the clutch pedal you should see a pair of wires and a switch. if you splice those two together, and when you turn the key it cranks, you've found your problem.
Edited 1 time(s). Last edited Friday, April 04, 2008 8:20 AM
ok well i'm sorry about the way i was explaining every thing i just learning how to do this
