I drove these things all of the time when I worked at NJ Department of Transportation. They run by default on CNG and will switch over to regular gas when the CNG supply is depleted. They run like crap on regular gas.
i wish i could get the part number for the hinges on that filler area, and adapt them to the other side for putting gas into the car
1998 Chevrolet Cavalier
5-spd
Sean Gulden wrote:I drove these things all of the time when I worked at NJ Department of Transportation. They run by default on CNG and will switch over to regular gas when the CNG supply is depleted. They run like crap on regular gas.
they shouldnt. the only diff between cng cav and regular 2200 is the extra injector and piping for cng. when running on gas it shoudl run jsut liek a normal 2200
id love to own one but i like my sunfire...maybe i shoudl do a conversion
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
I have a 2003 and 2004 CNG cavalier. I have also owned a 2001. The 2003 and up have the ecotec with a second fuel rail with cng injectors. The older ones put the CNG right into the intake with a gas/air mixer. They work pretty well and I have not had any problems with them. The older ones were a little lazy off the line and on hills, but the ecotec's run pretty well.
BlkCav wrote:i wish i could get the part number for the hinges on that filler area, and adapt them to the other side for putting gas into the car
i'm with you.. could make for a nice and clean route when going for a shaved gas door
You Know How It Is
the hinge part is on the cng connector. if you get that plate im sure it comes with it
Machzel08 (Teh Jew) wrote:Sean Gulden wrote:I drove these things all of the time when I worked at NJ Department of Transportation. They run by default on CNG and will switch over to regular gas when the CNG supply is depleted. They run like crap on regular gas.
I bet since it is used to running with the CNG when you toggle to regular fuel the ECU needs a while to retune to the new fuel. However long it would take to burn in a new ECU. You think that could be it? Made sense to me
I think that the second fuel rail would be a nice way to inject some nitrous.
