i had my intake (still factory) all the way out and was giving the engine bay a good cleaning and i noticed a liquid in the box part that connects to the TB and stuck my hand in it.... it was oil
should i be very concerned or could it just be something from when i had my oil changed it came from the tube coming off the head overflow maybe?
boost is like ice cream, there's always room for it
there is a breether tube that goes from the intake to the valve cover, its meant so oil vapors get sucked into the engine and burnt up rather then vented into the atmosphere. Its an emissions thing. But since its puts a slight vacum affect (lots of air flowing over a the end of a small tube is going to create a vacum) inside the valve cover you will always have a little bit of oil thats gets sucked out into the intake.
Its normal.
good as long as its normal then i am happy but none of my other cars did that so i was a tad worried
thanks for the help
thats why some people use the mini K&N style breather filters. may not do any real thing for performance, but youve gotta figure...that oil is gonna get inthe the head intake ports, which are hot, and form varnish and gum, which will eventually need to be cleaned out. if you use the filter, and dont suck up the oil, you dont have to clean it out.
and, now that ive mentioined the use of breather filters...let the flaming begin...
Looking for something new? How about an off topic forum where you can truly express your opinions without interference of mods or admins?
Join verbalwarfare.com
http://www.verbalwarfare.com/forum.php?referrerid=86
As mentioned above, its normal, especially on higher mileage engines.
01 cav w/01 3400 gam gt 4t45e
on older vehicles replacing the pcv valve will fix it too.
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
on newer vehicle there is no PCV valve so that doesn't help
Patrick Myers wrote:on older vehicles replacing the pcv valve will fix it too.
On my 98 2.4 it's a CV not a PCV
You think you have oil in your intake box, try installing the Crane roller rockers in your engine. You have to dremel out a big portion of the baffle inside the valve cover to get clearance, so more oil gets sucked up that tube and deposited in your intake. A breather filter will stop that, but then you have to deal with the oil vapor being deposited all over your engine bay. I know what I am about to suggest might seem "rice" to alot of folks, but a cheap oil-catch can (search ebay) will help ALOT with this problem.
a catch can is very good advise
As stated above it is just your crankcase breather allowing oil to enter the intake. Eventually you will notice a build up in the throttle body and intake ports, i have found a shot of carb cleaner (o2 safe of course) works wonders for removing the buildup and allowing air to better flow to the engine.
well i think i might have found the problem... changed my oil today and drained out....ready.......6 QUARTS. 3 months ago i didnt have the time so i took it in to have the oil changed. so it went back and told them about it and they said that the ecotec takes 6 quarts which isnt right so they took the stuff out and cleaned it all for me thanks for the tips
6 quarts? Do yourself a favor, pull the plugs and look at them. I'd bet they got oil soaked from the extra quart and a half.
yeah there was 6 quarts in it i planed on changing the plugs today
