I have a 95 cavalier 2.2 I am repairing up having to replace the head gasket and a partial replacement of the front clip, while I have everything on the motor dismantled I can see it would be easy to replace a few things while I'm at that point trying to figure where the hook-up for a oil pressure gauge and temp. gauge would go on the block could anyone give me a idea where to look  Thanks
listening!!!
"Sunfire got stolen, all i have is the J to remember it by"
You'll find two plugs just above the oil pressure switch, put you pressure feed tube / sending unit in one of them. All the needed adaptors should come with the guage.
 As for the temp guage you'll need a t-fitting to adapt a sending unit / temp probe to the temp sending unit on the drives side of the head, on the water manifold/EGR adaptor, next to the water outlet.
Thanks alot for the information " Big Help"
