I'm having a problem trying to figure this out i thought i blew a highbeam fliament in the pass. side headlight... but yet when i changed it it still wont light... checked fuses but still nothing... please help...
Swap the bulb with the driver's side first...  see if that changes anything.
Stock bulbs? Or higher wattage replacements?
Could be a fuse... could be the DRL relay... could be a burnt wire...
WOW don't know why it came out so big. Was small in the preveiw .
Hey look, it's me fisting a truck
Nothing like a gyno exhaust... so big you can rebuild the engine thru the tail pipe
You like those trucks, uh?
I didn't think it would be appropriate to drop my pants and start @!#$ it, so I fisted it instead.
DFresh wrote:I'm having a problem trying to figure this out i thought i blew a highbeam fliament in the pass. side headlight... but yet when i changed it it still wont light... checked fuses but still nothing... please help...
had a similar problem on mine the day I drove it off the lot
try taking off the bulb and looking inside the harness to see if it is burnt on the inside.  mine was
+/- $35 for the harness and a little soldering
