Anyone know offhand the size of the stock exhaust? I'm looking at a catback kit with 2.25" piping and wondered how big of a difference that would be.
1998 2200 auto
i thought it was 2in....
i could be wrong i just remeber someone saying that a while back
97cavy22 wrote:i thought it was 2in....
I want to say it's something like 1 7/8" but pretty damn close to 2"
Hmmm ok. See my friend put the same catback system on his Civic which had a 1.5" exhaust stock, and it definitely pulls hard from 4 to 6k now. But, that's a 1.6L Civic so I wondered if anyone had any input on decent sizes for Cavalier exhausts.
2.25" if you're all motor
on my 2004 ls sport it is...2 inch INSIDE diameter(about 2 1/8 outside) from the flex joint to the flange after the cat&02 sensor, 2 inch OUTSIDE diameter(bout 1 7/8 inside) from the flange to the tailpipe. i did these measurements with a set of dial calipers from the machine shop i work in, not a tape measure so they are acurate, at least on my year and model. it is done this was so that the pipes fit inside eachother at the flange...allowing a double seal. also note the cat-back section is horrible. beyond being too small it is crushed in some places to maintain a constant clearance around undercar features such as suspension and the gas tank. 2 1/4 cat-back is very high on my list to do.
Looking for something new? How about an off topic forum where you can truly express your opinions without interference of mods or admins?
Join verbalwarfare.com
http://www.verbalwarfare.com/forum.php?referrerid=86
