Well the motor in my Cav. is cooked. I am considering this swap and i am looking @ what it is going to cost, what im going to need, how much work will it take. I have priced it out and im looking @ about 2100-2500 to put an LD9 back in and a new clutch for the izuzu. i know alot of harnesses will need to be altered and hoses but i need to know what parts i need to find...
Now since i began considering this swap i realized that i can get the motor and tranny i need to do this swap for about 1100 or less. I have made a short list of what i think i will need, please add on if you kno whats required....All the info i have found so far the people are using 2.2's so a tranny swap is not needed....
so far...
3400 engine
3400 ECU & Harness
2.2L OHV 5speed Getrag
shifter assembly
shifter cables
keep the list going so i can see what all is required.........thanks...
^ MUNCI from a 2ed jen Z.....
Chris
'02 Z-24 Supercharged
the grand am down pipe has to be redone but the flange will work i have the down pipe that has been redone in my garage , the down pipe will hit the frame and it will leak when you are in drive or hitting the gas !
http://www.danasoft.com/sig/lman1.jpg
did you ever figure  anything out about your downpipe situation ?
my biggest issue with starting this swap in a few months is the wiring, if i go with a stock grand am ecu and wiring harness, what am i gonna have to do to get my stock gauges to work, if its just a matter of splicing the wires then its all good, but i have a feeling it isn't going to go that well. Also the airbags, im assuming they wont be affected, but id rather know for sure
keep me informed i would be interested too. my friend done one on an 88 beretta and it flat screams. 14.88 stock!
2004 Cavalier, 2.2 ecotec, 5spd getrag
do you ever notice that the ones who talk the loudest have the least to talk about?
Well......
I was under the impression that one installing a Getrag tranny into a 95-99 car one of the mounts lines up and one does not..........i think i got some bad information, the rear is close but the axles dont line up and the tranny seems to sit too high.....any thoughts guys ????
i want to use the Getrag as its a more solid tranny, and all my stuff fits it, i dont want to go back to an izuzu.....
