i've got a 98 chevy cavalier with about 74k miles on it... my problem is that when i try to take off in first the car just goes THUNK THUNK THUNK...and almost wants to die when i try to take off... it almost feels as the the tranny is catchin on something and is messing with the axle... i dont know how to explain it.... recently i just had a new tranny put in... it has about 26k on it so i'm wondering if its something in that... or could it be that i have bad cv joints? any ideas let me know plz
seems like  the same problems i'm having, it just happens when i start driving, then it gets back to normal.  I have no clue what it is, changed the spark plugs and fuel filter and no luck.
sounds like a weak clutch to me and isnt grabbing to is full potential. does the rpms drop to like 500 or 600 when you release the clutch then jump up a little when you start to move forward
i dont have a tack so i dont really know... its only when i start off in first and let off the clutch... like i'm letting off too fast but i'm not.... must not be grabbing right
ya sounds like the clutch to me maybe the flywheel is shot
mine did that and i ended up needing a new tranny
If your name is Mr. Crunch, and you joined the Navy, would you eventually be Captain Crunch?
the shop probibly f-ed up putting it in I know like 4 people that has had retarded problems like that over tranny jobs not putting the cv's in right and having them fall out while driving  and not bolting the tranny to the tranny mounts (this was my prob) not the cv prob but after I had my second tranny job after awhile it started to jerk around bad once I started to drive it normally cause I took it easy for awhile really easy because it felt weird I looked around and the top tranny mount wasnt even on at all and the second one was I dunno know  it was in but I remember somthing was up bolt not in all the way or somthing I fixed it though and it got all better it just thudded bad like a bad mount when you step on it thud you could even hear and feel it pop around corners and harder brakes im surprize it didnt mess even more stuff up thats why I do 99% of my own car work I dont trust many other mechanics out there
he isnt trying to learn to spell
he is helping the issue this person is having,
if its not about the problem then dont post.
back to the subject
if you want to find out if its the clutch. giver @!#$ through 2nd, shift into 3rd quickly and keep gunning it
if your engine sounds like its doing some high rpms but your are not going anywhere its your clutch.
if you had a tach you would see your rpms go to like 4000 rpms but doesnt feel like your accelerating, that shows the clutch is slipping
and if it is slipping, you well also smell burning clutch, you have a bad clutch .
but if your clutch is grabbing good and not slipping while flying through the gears then it could be flywheel or tranny like stated before.
good luck
