anyoen else get water drip on your feet when you run the ac for a while....
<a href="http://www.midnightaddictions.com"> <img src="http://registry.gmenthusiast.com/images/black03cavi/thumbnail_personal_pic.jpg"></a>
is it particularlly humid where you are cuse it might just be serious condensation
yeah.....that sounds not good batman..
There is no way possible.
What AC component is remotely close to that?
The ducting under the dash shouldn't allow such water condensation either.
_____________________________
WWW.BEIRUTNIGHTS.COM WWW.DI.FM
There should be a tray under the evaporator coil to colect the condensation and pipe it out side. It is probly cloged.
The mopar K cars had a problem if you turned a corner to fast it would dump watter on your feet.
thats not good huh??
well, ive never had this happen to me before until i was driving home the other day on the highway. i had the a/c on full cold, and i decided to open the sunroof
anyway, it was about 95 degrees outside and humidity was also near 90%. after a while, there ended up being condensation on top of my a/c vents, and also, i did feel two drips on my shins. i guess its sorta normal.
its getting worse.. the whole passerngers side floor is always soaking wet. it like drips constantly... im gonna pull it aprt this weekend.. and see whats wrong with it.
no
Sinister Ambitions
when your girl is getting on your last nerve f*#k her dont fight her
SCOTT: ITS YOUR HEATER COIL.....trust me....i had a 1987 z24 and it done it. you have a bad heater coil.
ClassGlass / RkSport / Eibach / Motegi / Ractive / Borla / K&N
if that was the case wouldent it be antifreeze?? im gonna pull it apart on saturday... the car has less than 50,000 on it... i dunno ill let u know
scott: it does it ONLY when your air is ON right? my 87 z24 done the same thing.....maybe i told you the wrong part....but hey its been about 8 years ago....try checking your drain line, maybe its clogged up also. hope it goes well for you. good luck .keep us informed.
yeah... the thing is, my ac still leaks on the outside just like normal...
scott
happens once in a while on my 05 on a humid day...but its a drip every 20 mins or so....what you have sounds alot worse.
well thats how it started....
hey midnight: im not trying to jack the post or anything, but werent you trying to sell your cavy at one time?.....i thought i saw it on ebay awhile back. do you still want to sell it?
